Geil 6400 on GA-965P-DS3 - Strange
20 Sep 2006
Hi,
Just built my new system and everything seems fine apart from the memory.
System Specs:
E6400 @ Stock with Stock cooler
GA-965P-DS3 @F7 BIOS
GEIL 2X512MB PC2-6400 CAS3
Enermax Liberty 500w
X1950PRO
After the system was installed I have had a few application errors and wondered if the memory was ok so I ran Windows Diagnostic and Memtest86+ to check for problems and I found lots of errors.
I read up and found that this board has a standard mem voltage of 1.8v and high spec memory can have problems so I ran tests at different voltages, here are the results:
Geil Stick 1:
+0.1v = errors on the MATS+ test Windows Diagnostic
+0.2v = errors on the MATS+ test Windows Diagnostic
+0.3v = No errors on either Windows Diagnostic or memtest86+
Geil Stick 2:
+0.1v = No errors on either Windows Diagnostic or memtest86+
+0.2v = No errors on either Windows Diagnostic or memtest86+
+0.3v = Loads of Errors
I am not sure what else to try, played about with the timing but didn't seem to do anything.
Should I just return the sticks or is there anything else to try?
Any help would be appreciated.
Cheers, Dave
I've just had probs with my Geil ram, apparantly there is a lot of bad Geil going around at the moment. I'd suggest contatcting OcUK support as they were really helpful for me.
