Geil DDR2 @ 800 - 3-3-9-1T
1 Dec 2002
The declared spec is 1.2 GHz (600 MHz DDR) at CAS4 4-5-10 latencies. At 800 MHz, the memory is specc'ed to work at CAS4, 4-4-12-2T - but that was far from the truth. We got the modules running with zero problems at CAS3, 3-3-9-1T on both Intel and AMD platforms. This was achieved on more than one motherboard and we managed to get confirmation that this isn't the isolated case with our sample.
Im guessing that is good and we should be drooling? (ive been away from the game a long long time)
http://uk.theinquirer.net/?article=34166
Hi there
Can get these parts no problem but they do cost approx £100-£150 more than the current PC2-6400C4 kits we offer from GeIL, so would people pay it for what is quite a small increase and one that only benefits the extreme overclock realler pushing the boundaries?
Plus memory prices at the moment are unreal. Prices are up by over 50% from what they were 4-5 weeks ago.
When we first got the GeIL PC2-6400C4 2GB Kit We sold it at £110+VAT, wheras now its upto £150+VAT and pricing carries on increasing. This is not just GeIL its all memory including Corsair etc. and prices look set to carry on increasing.
DDR pricing has gone unreal too as now production is finishing and hence stock very hard to get and prices will go up massively.
lol they look the same memory, just with a diffrent timings and a higher voltages
problay just the same memory type on them just tweaked
not worth 100 or 150 pounds more
yeh gibbo i picked up 4gb of that geil @ the £129 inc vat excellent value
now seeing their @ £170 inc vat
no got a board yet to run them lol
Ithink you'll find that the cheaper 6400 uses is Elpida, whereas the higher specced uses micron IC, I have read this I haven't actually removed the heatspreaders and looked so I'm not absolutely certain. Also the higher priced is the cream of the crop extra testing etc that's where the price increase comes from labour is not cheap in Taiwan any longer.
Gibbo might be able to confirm it for you.
Yeah, it might look the same but it has to be different chips underneath. I don't see why it isn't rated 800Mhz though, or given a different name than the cheaper 6400.
I'm gonna try running mine at 667Mhz 3-3-3-15, just to see if those timings are possible with the regular Geil.
i searched whole web m8 and no1 *** what memorys it is
Elpida memory had problems, look @ ocz wich jumped gun with ddr2
high spec and gskill ,they had to all ditch Elpida and move to micron
so why would geil choose Elpida when it dont work on many chipsets
only diffrence between overclockers geils and that new geil is voltage
geil recommends 2.1 volts for, that sell on overclockers
mine is even stamped maxium 2.1 volts
that new stuff recommends 2.4 minimum
so in my book its all about voltage for ddr2
remember fatbody 9 chips
http://www.xtremesystems.org/forums/showthread.php?t=94017
Ok, I've just booted up with my Geil 2x1Gb PC6400 at 667Mhz, 3-3-3-12 @ 2.1v, CPU at stock 266fsb, 4:5 divider.
Seems stable enough, so I'm going to see how far I can push it at 2.1v.
I've no intention of trying 2.4v on mine though, or anything over 2.1v. I'll leave that to one of the guys with money to burn :).
EDIT\
I didn't get very far :(. 675Mhz was ok, but 680 gave a bsod after running everest. It probably would reach 800Mhz with 2.4v, but I'm not risking it. I'm happy with 4-4-4-12 :D
EDIT\
Hehe indeed, im just happy I just made 4-4-4-12 :) And it's solid as a rock!
seems 965 chipset and 975 vary
i seen people boot up with 1.8 volts at correct timings
with 975 with geil and gskill GBHZ, but 965 chipset requires more volts to run correctly, and slacker timings for it in order to boot @ SPD timings
