- 19 Oct 2002
- In my kennel
Hi,
I recently bought a new system:
The BIOS and CPUZ read the SPD timings incorrectly:
When I manually set the timings to their correct values (i.e. 4-4-4-12) Prime 95 reports errors after a few seconds and Windows frequently crashes to BSOD forcing a reboot.
If I leave the timings at their incorrect values (i.e. 5-5-5-18) the system seems stable: ran Prime 95 for 3 hours, not had any BSODs
Strange thing is, Memtest86+ 1.70 runs 3 full cycles (got bored and stopped it) stable for both sets of timings.
CPU temperatures are about 30C idle and 45C under load. I've disabled Speed Step and Enhanced Halt (C1E), have left Thermal Monitor (TM2) enabled.
Any suggestions on what I can do to run the memory at it's advertised speed and what is causing Windows instability?
- Core 2 Duo E6550
- Gigabyte GA-P35-DQ6
- 2Gb Geil PC2-6400 400MHz 4-4-4-12
- Corsair HX520W power supply
- 8800 GTS video card
Does the Gigabyte Easy Tune give reliable voltage readings?
