GeIL not running at proper speed? Please help!
9 Nov 2008
Ok, I bought some GeIL 2GB (2x1GB) PC2-6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) for my new build using an Abit AX78. I manually set voltage to 2.1 in softmenu setup, which is the DDR2 Voltage option right?. I set the timings to 4-4-4-12-24-2T, yet when I open Z-CPU, it says its running 1.8 voltage and at 400mhz?? FSB:DRAM is 1:2, is Z-CPU wrong or am i missing something else here? Cos it should be running at 800mhz right? or higher with these settings? Any help is greatly appreciated, I'm a bit of noob at this.
Your ram is running at the right speed, it's DDR = double data rate so 2 x 400 = 800mhz.
Oh and welcome to the forums :)
