Geil ram overclock settings
16 Dec 2005
Halifax W'Yorkshire
hey. ok iv overclocked my machine and now my rams running at 333mhz (check the screenshot)
is there any way to get it to 400mhz without effecting the rest of my overclock etc? cause i want to keep my 3ghz E6600 overclock if possible cause i dont want to go too crazy. its how i popped my old amd 4400x2 lol
Currently your RAM is set to 1:1, not sure if your board has done that by default.
I guess there should be an option in BIOS called Advanced Chipset Features. It may help to increase the volts on the RAM a tiny bit.
iv set the ram timings my self.
i just wasnt sure how to get it to 400mhz without having to faff with everything else
i see the options:
use 4:5 divider to get 416mhz
or
use 400fsb and 8x multiplyer on cpu.
but then my rated fsb would be 1600 isnt that too high?
