Gelid Fans.
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Gelid Silent 120mm Quiet Fan @ £7.99 inc VAT
Designed for Silent enthusiasts GELID Silent case fans provide additional airflow without increasing noise levels and at affordable price. Precisely balanced fan blades and long life Hydro Dynamic bearing guarantee ultra low noise. Furthermore, fan mounts replace traditional screws which are made of high quality, temperature resistant, extra long lasting rubber. They are designed to stop vibrations from the fan motor transferring into your PC case.
- Silent Operation
- Optimised Fan Blades
- High Airflow and High Static Pressure
- Rubber Fan Mounts
- Long Lifetime
- Air Flow (CFM): 37
- Bearing Hydro Dynamic Bearing
- Cable Length (mm): 500
- Connector: 3 Pin Molex
- Dimensions (mm): 120 x 120 x 25
- Fan Speed (RPM): 1000
- Noise Level (dBA): 20.2
Only £7.99 inc VAT.
ORDER NOW
Gelid Wing 120mm UV Blue High Performance Fan @ £14.99 inc VAT
The WING UV Blue case cooling fans are premium quality, UV reactive, ultra-quiet, dust and waterproof for gaming enthusiasts. This series features a unique bearing with patented design, winglet fans blades and low starting voltage. Only the highest quality materials have been used to manufacture this state-of-the-art cooling fan. Control the fan RPM speed according to your desire using the supplied voltage regulator. To add to the silence, fan mounts replace traditional screws and are made of high quality, ultra-soft silicone which stop vibrations from the fan motor from travelling into your PC case.
- Air Flow (CFM): 64.3
- Bearing Nanoflux Bearing (NFB)
- Fan Speed (RPM): 1500
- Noise Level (dBA): 12 - 25
Only £14.99 inc VAT.
ORDER NOW
Gelid Wing 92mm UV Blue High Performance Fan @ £12.98 inc VAT
The WING UV Blue case cooling fans are premium quality, UV reactive, ultra- quiet, dust and waterproof for gaming enthusiasts. This series features an unique bearing with patented design, winglet fans blades and low starting voltage. Only the highest quality materials have been used to manufacture this state-of-the-art cooling fan. Control the fan RPM speed according to your desire using the supplied voltage regulator. To add to the silence fan mounts replace traditional screws and are made of high quality, ultra-soft silicone which stop vibrations from the fan motor from travelling into your PC case.
- Air Flow (CFM): 39.8
- Dimensions (mm): 92 x 92 x 25
- Fan Speed (RPM): 2000
- Noise Level (dBA): 11 - 22.5
Only £12.98 inc VAT.
ORDER NOW
Gelid Wing 80mm UV Blue High Performance Fan @ £12.98 inc VAT
- Air Flow (CFM): 28.1
- Dimensions (mm): 80 x 80 x 25
- Noise Level (dBA): 10 - 21
ORDER NOW
OcUK should get the Gelid PWM LED fans in stock. They're as good as 1800 RPM Gentle Typhoons but with the added bling factor and are PWM so will quieter at idle:cool:
