GELID Intros Tranquillo Rev. 2 CPU Cooler
19 Dec 2003
Grimsby, UK
http://www.gelidsolutions.com/products/index.php?lid=2&cid=12&id=64
GELID today announced a revision of its Tranquillo CPU cooler. Revision 2 of this aluminum fin tower-type cooler comes with three major changes, an updated heat pipe profile; a new AMD socket clip that allows 4x 90° installation; and an improved heatsink shape.
To begin with, the four exposed-copper heat pipes project out of the fanned out better, with the heat pipes almost reaching the periphery of each of the fins.
Next, a new AMD socket clip allows you to orient the heatsink in the same way you can with the square bolt layout of Intel sockets (90° in any direction).
Lastly, in the space between the CPU base and the bottom of the aluminum fin stack, GELID put a larger heatsink than the one found on the original Tranquillo.
The Tranquillo Rev. 2 is certified to work on Intel sockets LGA1366, LGA1156, LGA1155, and LGA775; AMD sockets AM3, AM2+, and AM2. The company did not give out pricing information, but usually revised SKUs carry the same market prices as the originals they're revisions of.
Source
Yeah bought one for a friends Asus Crosshair IV, AMD 1090T build last year, for the price it's a good buy.
Hopefully this new revision of the Gelid will knock a few more °C off.
