Gelix Tranquillo CPU Cooler
11 Jul 2011
England, UK
Hey Guys.
Im just wondering about this cooler.
Your motherboard is mounted vertically in the case.
And the cooler sticks to your CPU. Or does it?
And then that huge heatsink hangs out horizontally, isnt that going to put a lot of strain on the CPU and pull it out of the socket?
Or is there some sort of plate you stick to the mobo, and then screw the heatsink to that?
Cheers.
It bolts through the motherboard and is secured across the back.
Its a well used and tested cooler.
You think the gelid looks big? try a Noctua NH d14!!!
