Gen8 Hardware failure?
7 Apr 2004
near Bristol
Hey, I am having some issues with my microserver that perhaps some of you may be able to shed some light on for me.
I'll start with the setup and go from there.
HP Gen 8 microserver
6GB of ECC mem (2GB + 4GB)
1 x 80gb 2.5" in the optical bay
4 x 3TB WD Red drives using the B120i controller
I have owned the server setup for around 2 and a half years running Xpenology, fault free up until a few months ago.
Initially I set the system up with all the drives in JBOD, I wasn't bothered about redundancy so thought I would just go with the simplest setup when I was trying to get to grips with setting up a server for the first time.
After about 2 years fault free service it crashed several times, I was able to repair the data drives and carry on, until the array crashed again. This time I was no longer able to even recognise the drives with the server.
So I took each one out and scanned it with the WD lifeguard program on my PC, 7-8 hours a drive! All were apparently fault free, so I RMA'd them all to Western Digital.
I now have brand new drives, they were all recognised by the server, I set it up with OMV this time, setting the drives up into a Software 0+1 Raid setup, all was well for 3 days then the server crashed again, leaving all the drives now unrecognisable to the server (both in the BIOS and in the OS).
My limited experience with servers and linux isn't helping much, but I have always been fairly competent with the hardware side of things, though it has been a fair few years since I have been "into" computers.
I am thinking that this seems like a hardware failure on my servers motherboard, perhaps the raid controller that looks after the 4 bay slots?
Anyone else had any issues with the gen8?
Cheers in advance
Mike
Have you checked you memory is ok as systems tend to crash when that is faulty. I've had boxes running fine for a while until the point when the faulty memory was attempted to be used. Run something like memtest86 on it?
Ok, a late update, I ran memtest on both sticks of ram together and individually and they were fault free.
To back this up I ordered 2x4gb of memory and tried that as well, all fine and dandy.
However my hard drive bays, 1-4 all seem intermittent still. Yesterday the front light changed to red instead of blue, which I believe points to a power issue. So I'm starting to think my PSU is packing up, replacements aren't cheap to check...I really can't be bothered to tear my main pc apart, to check with my pcs PSU.
Might be time to replace the server, given the sky high prices of the gen8 and spares.
Unless anyone has any suggestions? Cheap ones that is!
If it was me I'd start again like you say rather than chase the Gen8 issues down unless you really want to go the full Gen8 repair route - with what you've checked already it can only really be raid controller, motherboard or PSU.
You've just missed a £50 cashback on Gen10 Microserver (it's currently only £20) but if you're happy with the stock performance on a Gen8 the Gen10 will be more than adequate. Stick your new drives in it and away you go. Selling the faulty Gen8 on MM or eBay will recoup costs too.
Yeh I've been looking at the Gen10, it appears to lose iLo though and has a soldered cpu, I always liked the idea that should my server need some more oomph I could throw a Xeon in there.
What is the ML10 Gen9 like? It appears to have a cheap Intel processor but at least it's upgradable? Has iLo etc. My server sits in an unoccupied office, so as long as it doesn't wake us up in the next room the noise level should be ok.
I'm currently giving an old pc I have by my feet a go at powering some of the drives to see if this helps. In doing so I noticed I have my 2.5" drive installed in the ODD port, but connected via a molex splitter, then to a molex to sata connector. I didnt power the 5th drive via the floppy power connector so all 5 drives are on one cable. I am secretly hoping this cheapo splitter could be the cause of the instability, wishful thinking is more likely, but I can sit and hope everything is ok now I have removed it...
Time will tell...Probably the next 5 minutes..
If noise/space isn't an issue then yes a more corporate-aimed server will do the job better especially if it's in an unattended remote office
I thought about the Gen10 lack of iLO and upgrade and in the end it wasn't an issue for me as I'd always upgrade way before performance became an issue (I've just got one to replace my N40L) and it's in the same room as my main PC so together with RDP access is never a problem either
Ok, I pulled the molex splitter that was powering the 5th ODD drive from the main molex connector for the front bays, ordered and fitted a "floppy to SATA" connector to power the ODD hard drive separately.
It's currently without issue....omv is now running, with 3 drives pooled with unionfs and snapraid using the 4th disc for parity.
It literally went from hard drives disconnecting (presumably powering down as I could hear them powering up repeatedly) every few minutes to total stability. Maybe that 12v rail was overloaded. What doesn't make sense is the previous 18months or more of uptime where I had no issues
Oh well, watch this space!
