Well, first of all thanks to those folks who gave advice on my new set up, the beast has been born, and despite a couple of hiccups ( thought I had a £2000 brick this morning >.< ) it all seems fine for t'interweb.
First, a resume of the spec build
Antec P180 EU Aluminium Super Miditower - No PSU
Hiper 580W Type-R Modular PSU SLI/CrossFire Certified - Blue
BFG 680i SLI nForce Intel socket 775 DDR2 ATX
Intel Core 2 Extreme QX6700 Quad Core 2.67GHz Socket LGA775, 8MB
2 of Corsair 2GB Kit (2x1GB) DDR2 PC2-6400 (TWIN2X2048-6400C4D) DOMINATOR ( yup thats 4Gb total!! )
BFG GeForce 8800GTX 768MB GDDR3 HDTV DVIx2 PCI-E
2 of Western Digital WD5000KS 500GB SATA II 7200RPM 16MB Cache ( Gif terabyteage! )
Sony AW-G170AB2 18xDVD +/- ;RW/RAM Dual Layer Writer Black - Bare Drive
All running on
Windows Vista Home Premium
Points of note for anyone who thinks about building a similar machine:
As far as I can see, they PSU and Case are not entirely compatible, Ive had to remove the additional 120mm case fan which is supposed to pull through the HD bay and through the PSU. Also, while the PSU is good, it doesnt have an 8pin ATX, only a 4pin, which is a bit of a crippler. Also, without a degree in ELectronic Design Engineering, I cant for the life of me see how I could get another BFG GeForce 8800GTX in there and get power to it!
So anyhoo, the issues Ive had so far, and some tips for anyone who *may* come up against similar issues to me.
Drivers
Well.. Vista is barely a month old, so all the drivers that came with the components you can more or less sling right in the bin. nVidia do have 680SLi nForce drivers available ( Beta ) as well as a beta driver for the GeForce 8800GTX. If your board ( like mine ) has the new realtek HiDef sound chip the driver for this can be grabbed from http://www.realtek.com.tw/ for the full 5.1/7.1 effect.
Well, thats the stuff I have got sussed covered.... here's the stuff thats causing me to loose sleep.
Memory
Fitted 4Gb of Corsair DOMINATOR. BIOS & POST See 4Gb of RAM. SiSoft Sandra reports 4Gb of RAM. Windows Vista Home Premium reports 2.75Gb of RAM, WTF?!? and has the cheek to declare that this is what is holding back my system. I dont know if this is simply a reporting issue, or if Vista isnt using all the available RAM. Anyone got any thoughts on how this could be checked? ( I have run all the modules seperately in all the memory banks on the Mobo, they are all pukka )
Gaming
You know that horrible "beep" you used to get when something was on the verge of dying a horrible, smelly silicon death? Well everytime I play a 3D game.. thats what I hear. System temps look to be ok to me... CPU up to about 50°C, System 36°C and GPU between 80° and 90°C. Again, anyone got any thoughts, either what is causing it, or what I could use to diagnose it?
EDIT Oh yeah, and then occasionally, and for seemingly no reason, my character in what ever game Im playing will continue running in the direction I last pressed ( eg left ) despite me not touching the keyboard...
CHeers Folks
Phoo
All running on
Drivers
Memory
Gaming
CHeers Folks
Phoo
