- 7 Jul 2013
I have been out of the PC game for quite a while, and bought out of retirement my old 780i/QX9650 Rig, which is water cooled via a custom loop (CPU Only), so decided to do a bit of shopping and managed to pickup a GTX280 Water cooled for just over £20, and as i already have one of them in it thought I would set it up on SLI again.
I have never changed the liquid in the system which I know you are ment to do after a long period of time, I also didn't store it dry (stupid I know) so am going to change the liquid in the next few days (any suggestion in what is good these would be much appreciated.)
Should I also replace the piping? all the Barbs look ok, so wasn't going to change them? Have run it for leaks and had no issues at all which isn't bad for a system i put together in 2008.
Any other suggestions on what I should do would be very much appreciated.
Thanks
Rich
Thanks
Rich
