Hey,
Just wondering if someone can help me with a build, just wanting to know if it will all work together/there's some things I should change!
http://www.overclockers.co.uk/showproduct.php?prodid=GX-112-MS
MSI GeForce GTX 570 1280MB GDDR5 PCI-Express Graphics Card
http://www.overclockers.co.uk/showproduct.php?prodid=MO-091-LG
LG W2363D 23" TRUE 120Hz 3D Widescreen LCD Monitor
http://www.overclockers.co.uk/showproduct.php?prodid=CP-368-IN
Intel Core i5-2500K 3.30GHz (Sandybridge) Socket LGA1155 Processor
http://www.overclockers.co.uk/showproduct.php?prodid=HD-021-CS
Corsair Force Series 3 120GB SATA 6Gb/s Solid State Drive
http://www.overclockers.co.uk/showproduct.php?prodid=MB-360-GI
Gigabyte Z68XP-UD3P Intel Z68
http://www.overclockers.co.uk/showproduct.php?prodid=CA-196-CMCooler Master CM-690 II Advanced Dominator Case
http://www.overclockers.co.uk/showproduct.php?prodid=SW-127-MS
Microsoft Windows 7 Home Premium SP1 64-Bit
http://www.overclockers.co.uk/showproduct.php?prodid=CA-037-CS
Corsair Enthusiast Series TX 650W V2 High Performance '80 Plus Bronze' Power Supply
http://www.overclockers.co.uk/showproduct.php?prodid=MY-290-CS
Corsair XMS3 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit
http://www.overclockers.co.uk/showproduct.php?prodid=HS-002-CS
Corsair A70 High-Performance Dual Fan CPU Cooler
What I already have;
Asus DRW-2014L1T 20x DVD±RW SATA Dual Layer Lightscribe ReWriter
Some WD 500GB HDD
http://www.overclockers.co.uk/showproduct.php?prodid=SC-002-AS&groupid=701&catid=11&subcat=
Asus Xonar DX 7.1 PCI-Express Sound Card
2 SATA cables
Mouse/Keyboard/Headset/Speakers.
Will this all fit together and run smoothly?
Is the PSU big enough?
Can I OC the CPU to 4.40GHz?
Do I need any more cables?
Does the monitor come a DVI cable?
Is it hard to install the SDD and put Windows7 on it along with a few games?
Thanks!
Some WD 500GB HDD
2 SATA cables
Thanks!
