General cooling help needed :)
9 Jun 2008
I've got a Hiper Osiris case which has 1 intake fan at the bottom front and 2 outtakes on the back of the case at the top, pretty standard.
Now when I built my PC I just had some basic OC in mind which I am doing right now, the 3 cases fans are loaded with 3 Noctua 120mm NF-P12, my CPU has a set of Enermax magma twisters. It's all controlled via a Zalman fan controller.
I'd feel more confident if there was a good fan on the front to push a decent amount of cold air into the case, because I don't beleive the Noctua is up to that task. It's a 120mm slot and would be controlled via the Zalman controller so I can turn it down when just browsing so noise isn't a massive concern, has anyone got any recommendations?
