general cooling
25 Oct 2004
just looking to get some cooling going. getting some high temps. was just wondering which fans give best cooling, not nothered at all about noise. also, which cpu coolers will give me most effective cooling and lastly, are the akasa thermal interface pads any good.
thanks
well yes, deltas have awesome air flow - but really are loud - i mean i used to think "yeah as long as its doing its job i don't mind noise" yeah when you have to turn the music up just to over power the roar of your computer its a bit silly - so I'm *Assuming* (hay i could be wrong) you probably don't mind a bit of a hum, in that case something like an Akasa Amber will do you fine, 120mm's are very nice
Thermal pads are nice and easy but to be honest your better of with a tube of arctic silver 5 does a better job and to be honest isn't exactly tricky to use, put plop a rice grain size-ish bit on the center of the IHS on your cpu, dump on the cooler and let mavity and pressure evenly spread it over the cpu :)
good luck mate
ta
alec
