Canjam is July 18-19, I will be going on the Sunday.
Pros:
Most neutral and tonally resolved headphone from Sendy/Sivga
Exceptional treble control — extended and peak-free
Excellent channel matching for precise imaging
Cons:
Cons: Linear bass — will disappoint bass-head listeners
i am still perplexed by the current reviews for the Egret online, even the ones on Headfi, for example:
I mean, other than upper end treble being peak-free, I can't agree with anything else, the imaging is nowhere near precise!
All of the reviews seem overwhelmingly positive for the sound which is odd because the SV021 Pro also had similar and they sound even worse as per my last post about them. On headfi someone replied to me when I posted a comment in a thread about those models saying they posted a negative review of the 021 Pro but got blacklisted by Sivga.
The comment about the bass I semi-agree with but do not agree that you got to be a bass-head to not like them, the bass lacks low end extension to the point even the HD600 exceeds the Egret.
I'm standing by my observations though regardless. It is a 6/10 headphone for the way it sounds.
I have not looked at the measurements and I can categorically tell you that it's not my ears, otherwise other headphones would also lack the same bass. I don't think it's a faulty unit either because the same sort of traits were observed with the LCD-5 which were then enhanced by PEQ.
Not all measurements reflect what is heard though remember, so cannot be used as the ultimate decider on how a headphone will sound.
Or the amplifier doesn't have good synergy - some headphones can have a massive impedance hump in the lower frequencies, etc. which might not mesh well with all amplifiers and so on.
That's generally dynamics though and not planars isnt it?
The long and short of it is that it doesn't have good bass at the low end, this much has at least been confirmed by other reviews as well so it is not just me. And yes the HD600 does have more immersive impactful low end bass, this is not a mistake of my ears, you can literally feel the bass. Also I don't see how missing low end bass can be a fault either as these are planars, this issue isn't something that generally exists with the tech, either the driver goes out completely if it's busted or it's in working order.
It's open back too so there is nothing to seal, not that this would be an issue anyway as the cup and pad size is smaller than the Hifimans (It's LCD-5 size) and surround the ear efficiently with no gaps on edges. I can hold the HE1000se 3 inches apart from each ear and still experience the same bass as with them on my head normally. That is what I expect when listening to a decent planar as that has been my experience with all but the LCD-5 and now Egret to date.
It's not this either as between 3 amps the same can be observed, and the A90D is transparent, high current, high voltage and super low noise as it is anyway. For ref one reviewer used the normal A90 with the Egret and the DAC was the RME ADI-2. Perhaps a brighter DAC is what makes them sound neutral to others I don't know, I don't have any bright sounding DACs any more, only smooth and warm, but even still I can make the X8 sound bright via the PEQ so it's not that either lol.
Having an opinion or expectation is fine, refusing to admit when you are mistaken in your reviews is not in my opinion.It has mid bass yes and I noted to that earlier anyways, it's sub bass that is distinctly absent.
I don't want to beat this horse to death either, it's really as simple as me having a certain expectation of a standard a headphone should adhere to given the price and the Egret does not meet what I consider to be good enough.
You are unbelievable, you didnt just make a subjective claim based on your preferences. You claimed an objective fact by stating they had less sub bass than the hd600 which runs counter to what is shown by measurememts from multiple sources.My review is subjective just like always, there is nothing I have been wrong about, I stated my observation, it has been used on 3 different amps, it isn't a fault with the headphone, it just does not sound good to the standard I uphold a headphone to at this sort of price range. I don't care what measurements say.
Question for anyone; does the amount spent on a USB to Optical adaptor make a quality difference?
So if I want to convert USB to Optical will there be any discernable audio difference between using an SMSL PO100 (£31) vs a Topping D10 (£95-100)?
Basically want to ditch Windows as the daily driver again and don't want to use either the K13 or K15 over USB (as it would mess with my Tube Amp setup) so one option is to connect the Minisforum PC (as the Windows scratchpad/second PC) via a spare Optical input on the K15. Other option is to use the iFi stack (would have to use RCA inputs on the K15). But I'm wondering whether there is any difference in a cheaper vs. more expensive USB to Optical convertor. I know the D10 has it's own DAC and LCD screen that would increase the price/features and that's a major reason for the higher price (I sold my old D10B so could have used it again, doh).
Thanks in advance.
Considering its just a digital media converter i doubt there will be any difference. As long as ones not broken they should be the same
