I would like to overclock my CPU and my graphics card, i have used a windows based overclocking tool for my CPU and it can do 2.5Ghz with speedfan saying the temp is still under control.
Overclocking CPU:
Ok firstly the tool i have used is "Clock gen for Nforce 4" but everytime i reboot my PC is resets the clocks, so i was wondering if someone could help me with overclocking in the bios, i dont know where i go in the bios and what do i change. I have a AMD 3700+ so i was wondering what is the starting speeds and what should i change it to? Also what tools should i use to keep my system monitored i have speedfan to check the temps but is that accurate? i also have cpu Z so i know what my CPU is running at, any other tools that i need?
Overclocking Graphics:
With my graphics card i ahve a HIS 1800XL and i was wondering what tools i need to overclock my card? I have heard that Rage 3D tweak is ment to be good. Another one is RivaTuner 2.0 but i have no real idea, so could anyone who has experience overclocking the 1800XL help me out?
Thanks
Matt
Overclocking CPU:
Thanks
Matt
