Hi,
I have an EVGA 650W G2 PSU. I was excited (as much as you can be when buying a new power supply) to find that the cables were braided, which I thought might make cable management a little easier; however, the chunky 24-Pin ATX cable is quite stiff and hard to bend.
On my previous PSU - a Corsair RM series - the 24-Pin ATX cable was flat, and had reasonable flexibility once routed through the the cable port adjacent to the motherboard's ATX connector. This allowed the wires to feel like they were naturally making that turn/bend into the socket.
The EVGA cables feel stiffer, and I am worried that I should not be allowing them to bend too much -- I'm afraid of breaking the wires/pin connections.
I have attached a picture showing where I am bending the cable. Is this OK? I would say it has been bent. The cable is not long enough to route further into the case, so that I can have the bend elsewhere.
I'm probably just being overly paranoid. Everything's working. I just think I might take the time and redo it if anyone thinks it's necessary.
