General QoS question
11 Jun 2003
The Shadows (london)
If you set up QoS on IP addresses rather than a Subnet, will said IP address take any priority over other connected devices? or is it the case that that marked IP will have its bandwidth capped?
they are usually applied from the top down, so create rules for individual ip's above rules for a whole subnet.
theres a pretty good video series on the ubiquiti edgeos I found ages ago on youtube that might help:
Hope this helps
