General Question about Frame per second (FPS)
install monitoring software like Msi afterburner, enable in game overlay and check gpu usage it should be 100% in game if not its not being utilised for some reason either throttling or bottleneck although the latter is unlikely with that cpu
also check another game for same symptoms
Turn off Anti Alias or use 2x as you dont need it at 2160p resolution that will improve frame rates slightly.
Use MSI afterburner to o/c GPU eg add 100mhz as a start to GPU core.
frame rates you are getting are to be expected with a 1080.
