How come a lot of my games play really smoothly but at the start for about a minute or 2 they stutter? Take F.E.A.R for example, the test things says everything is 100% over 40fps or whatever is the highest, then in multiplayer on a new map or when i change weapon it goes all crappy for a couple of minutes?
Really annoying in car games when you go round a corner and it just stops and you then end up in a barrier/wall
Ive never seen a console game do this, so is it just the **** coding of programmers or do I need a raptor drive?
Norton does nothing but cripple performance. It would be ok if it could catch a virus, but then again that would make it useful software as opposed to the malware that it is. Creative doesn't need to run in the background unless you really want to add effects to all sounds. MBM is ok - but remember its probing your hardware every few seconds.
