So i have a new build and wanted to ask some questions on it
1) my cpu temp is 50 degrees at idle (i5 750) is this the norm (stock heatsink will upgrade soonish)
2) my xfx 5770 is running at 50 degrees at idle, again is this the norm?
3)lastly i have the p7p55d-e mobo, to turn off usb3.0 and sata 6 how do i do it...manual does not give clear directions heres what i think i should do sata 6 ports are labelled 5 and 6 on mobo should i just disable these and disable usb 3.0 controller
thanks for the help
thanks for the help
