General upgrade advice please
15 Aug 2003
Staffs
Been out of it for a while - haven't upgraded my board and CPU for five years!!!
Can someone please recommend a decent upgrade from my current system -used for a mix of gaming, music production and general media stuff.
No sound card needed as I have an external studio unit.
Intel 920 i7 @ 2.67
12gb ram
Radeon R9 200 3gb
Thanks
I cant remember which card I have -does this help?
Graphics Chipset AMD Radeon R9 200 Series
Device ID 6798
Vendor ID 1002
Subsystem ID 3001
Subsystem Vendor ID 174B
Revision ID 00
Graphics Bus Capability PCI Express 3.0
Maximum Bus Setting PCI Express 2.0x16
BIOS Version 015.041.000.000
BIOS Part Number 113-5E2490U-O46
BIOS Date 2013/11/27
Memory Size 3072 MB
Memory Type GDDR5
Core Clock in MHz 1020 MHz
Memory Clock in MHz 1500 MHz
Total Memory Bandwidth in GByte/s 288.0 GByte/s
That would be the R9 280x mate, had to google the memory bandwidth ;) (or another pointer)
You don't have a bad system at all if I'm honest with you. I'd start of by overclocking the CPU of you haven't already and that will require a new cooler :)
Then you can see how it goes and upgrade the GPU if necessary.
Thanks for the info on the card -its not that easy to find out!
I have gone for a new system build even though as you say its not a bad spec.
In fact I cant believe how long this system has lasted - I built it over 5 years ago and only upgraded the GFX card once!
My new system is Intel Core i7-4790K 4.0GHz 16gb ram - should be good?
