General upgrade - do I need to do anything specific?
12 Nov 2010
Hi,
I am going to upgrade my CPU/MB/RAM.
Do I need to do anything specific on the software side for this?
I will remove my realtek drivers before hand but I think that is all i need to do?
If you still have the licence key, maybe you could borrow the disk off of someone?
You will almost certainly need to reinstall the OS if the new motherboard has a different chipset.
Looking at Microsoft it seems I can do this without the key:
You can reinstall Windows 7 using Recovery in Control Panel, under Advanced recovery methods. This method reinstalls Windows 7, either from a recovery image provided by your computer manufacturer, or from your original Windows 7 installation files. You need to reinstall all of the programs that you added, and restore all of your files from a backup. For more information, see Choosing an advanced recovery method.
Will this be sufficient or is it a full reformat that I need?
