General Use / Video/Photo Editing and occasional gaming
MrX
MrX
27 Oct 2002
Nuclear Bunker
Hi,
It has been a while since I built a new PC (mine i7 has done v well over the years). I generally use it for general use and video and photo editing with only occasional gaming and don't need to run a game in full detail everything etc. I used to read CustomPC magazine before it stopped, hence not sure where to go for recommendations etc these days as that is no more.
I like Gigabyte motherboards and always have. I also like good quality PSUs and a lot of RAM. I like what I see now with AMD CPU's and would like the best bang for the buck but also to be fairly energy efficient. Storage I will add, but at least one fast solid state drive (my crucial has done well). Gfx card wise I see some mega prices and do not require something completely overkill, just something with a fairly large amount of RAM onboard and not to silly!
Ta in advance for your recommendations!
Best, Paul
The 7900 does very well with energy efficiency when you're running multithreaded, though the single/lightly threaded efficiency is not so great:
VRAM is the killer, I'm afraid. Nvidia want you to pay mega bucks to have more than 12GB. If your usage isn't super heavy on the GPU, I'd just get a 3060 12GB, though that's really a 1080p or light 1440p card for gaming.
You could consider AMD 9070/9070 XT, which are supposed to have been significantly enhanced for media encoding/decoding compared to the previous gen.
Nvidia mention some of the improvements in their latest gen in this article (page 27), which you could check if any are relevant to you:
If they're not relevant, a 4070 (from the previous gen) is cheaper than the 5070, which would you give pretty good efficiency for 1080p or 1440p gaming. A 4070 or 5070 can do 4K at a push, but not something I'd get for 4K AAA gaming.
The Lian Li case can do water or air cooling, so drop whatever you don't want. The average and top-end power consumption of the 7900 is very low, so it doesn't need an expensive cooler.
My basket at OcUK:
Total: £1,768.86 (includes delivery: £11.98)​
  • Like
Reactions: MrX
A curveball suggestion perhaps, but take a look at the Minisforum BD795i se. It's a high end laptop CPU (Ryzen 9 7945HX) on an ITX motherboard. The CPU itself is, to all intents and purposes, a desktop 7950x limited to 100w. The 7950x has an eco mode at 105w for comparison here
If you buy an AM5 motherboard and CPU separately then you're only looking at an 8-core CPU for similar money; bang-for-buck is incredible! The downside is that because it's a mobile CPU it's soldered to the motherboard, not socketed, and therefore not upgradeable later.
But for video and photo editing those 16 cores will really shine and gaming performance is decent too.
  • Like
Reactions: MrX
My basket at OcUK:
Thank you for this Tetreas
