- 29 Aug 2010
- Cornwall
Hi,
I just bought 4 Gentle Typhoons (are they really any good? the centre bit where the air dead spot will be is massive!!) and I noticed on the back it says the current is 0.083A, but the starting current is 0.36A.
Now this looks like it could be an issue as I was hoping to run all 4 on a fan controller using just 1 channel (all 4 will be going on my radiators so I was hoping to control them all at the same time). But the fan controller will only do 1A per channel.
Now this should run all 4 fine as 0.083 x 4 = 0.332A.
However will it be able to start them as 0.36 x 4 = 1.44A
Will this work? (i.e. will 2 manage to start, then once started drop to the lower current allowing the other 2 to start)
Do I have to get something like this (or this) if I want to run them on a single channel?
Thanks.
Thanks.
