German Ducky RGB TKL Keyboard convert to UK
15 Jun 2003
Darlington
If I was to purchase a German Ducky TKL RGB keyboard from Overclockers sister site & then fit UK keycaps all should be well? I presume that the Ducky keyboard would be ISO? The problem is I need an rgb tkl keyboard with mx reds and over here there is lack of them. Only one I can see with a standard key layout is the Asus Claymore but I am not keen on the casing and Corsairs do not have a standard bottom row key layout.
I guess, if it's ISO, then UK keycaps. If it's ANSI, then US keycaps.
I don't know for sure though. Some keys may be a bit weird (Shift, Alt, and Fn keys for example). That would be keycaps compatibility issues.
example :
http://blog.maxkeyboard.com/faqs/keycap-compatibility-and-size-chart/
My guess is, you're only interested in the 1x1 keys anyway. The rest of them should be the same whatever the language.
Ducky have peeved me right off, I have 4 Ducky Shine Keyboards at home, I think they are great, I love the quality and when I saw the Shine 6 Special edition I was very happy to give them some more of my money. But I have just found out after searching for ages that its only for the the US market....
Sort you life out Ducky or loose my custom and that of my family.
