Germanium X & Techforge Lightbox
8 Oct 2019
Hi All
Fairly new to this RGB stuff and looking for some advice ?
I have a Germanium X PC with the Techforge Light Box , its all good and works just fine!
My question is , Can I run an external RGB Led strip/light from the PC so the room lights the same colour as the PC ? ie: When the lights in the PC are Blue the led's in the room are Blue ? and so on ...
Thanks
Should be able to
I do it
Either using a 2nd led header if motherboard has it or a splitter
Then I just used rgb extension cable out through pci slot
