I have 3 monitors, a GTX690 and a GT210.
I'd hoped to plug my 690 into my Benq 120Hz middle monitor and plug the 2 remaining monitors into the GT210 so I could enable SLI Maximise Performance setting AND have the other 2 monitors working at the same time.
In the NVidia control panel it looks like its working, the SLI Maximise Performance tick box is ticked and the 2 other monitors are displaying correctly but when I run 3DMark SLI is not working, Only GPU #1 clocks up and goes to 99% usage, GPU #2 remains at 324mhz 0% usage.
Is this because the GT210 is a PCI-E card and therefore SLI cannot be enabled?
If this is the case, could I then get a PCI graphics card effectively freeing up the PCI-E bus and achieving the result I want?
Thanks in advance
Thanks in advance
