Get a 3-pin fan to use PWM?
If its for a cpu cooler, and plugged into the cpu cooler socket then just use speedfan (http://www.almico.com/speedfan.php ) to control it, i use it to manage my radiator fan, tell speed fan the desired temps you would like and it will only ever turn the fans up when u reach that temp or above it. Same goes for other fan headers.
But each mother board is different, i have 6 fan headers and only 2 of them are controllable via software, so it will just be a matter of testing.
As above really
PWM requires 4 pin cable and header, no way around it unless using software (as above) or get a fan controller
As above really
Actually that's not quite correct. Certainly, the most common PWM implementation used in PCs has 4-wires, but it's perfectly possible to run PWM on 3 wires (the mCubed TBalancer does this) - you just need a PWM generator to vary the pulse width on the positive wire. I built a couple of 3-pin PWM controllers and they worked as advertised, the only issue being the fans 'jerk' at very low speeds whereas the 4-pin ones stop. All you need is a timer chip and a MOSFET to power the fan.
http://www.bit-tech.net/modding/2001/12/03/pwm_fan_controller/1
WJA96 - you are a wealth of information and i'm glad you corrected me! :cool:
Didn't even think about the MCubed TBalancer and I have one myself :o
