Get an Antec 902?
5 Apr 2009
West Midlands
Is it worth upgrading from my Sonata III?
I want to as it is bigger and will therefore futureproof. Plus I could put my mums components into my Sonata III. I am a cable management freak, I love cases being neat and tidy. The 902 is good for cable managing I have heard.
Opinions?
The 900-2 is a good for cable management as it has the cable holes in the same place as the 1200. It is also a decent size. Though i think with the way the 24 pin connector is placed on the motherboard you will always have trouble with cable mangement. I have the same problem with my current motherboard.
You will probably want to get a modular psu while your at it. ;)
I was about to ask about the modular PSU. Though they are expensive... At least £100 for a good brand. And I don't want to be spending too much. Although I may just go for the 1200 even though it is around £40 more.. :( Come on OCUK give me some deals! :)
