im benching at 4.5 prime stable but only with an eye watering 1.300v ,
memory seems to make absolutely sod all difference , @1333 @1600 @2666 the overclocks the same , I cant get it stable @ 4.6 at all , and im pretty sure if I push the voltage higher im going to run into thermal issues . 4.4 is stable only after 1.280v even @ 1333 :/ ...
my old cheapo asrock z97 pro 4 board seems to OC better , could reach 4.6 prime stable @ 2666 @ 1600 @ 1333 . @1.300v
I try have my ring clocks @ 200-300mhz lower the clocks speeds. but unsure what to do with voltage with these.
im unsure how high im supposed to go without risk of killing it .#
wahts the concencus with Bclk overclocking on haswell
whats max safe voltages and temps I should be aiming for ...?
i7 4770k
TG Xtreem @ 2666 xmp
i7 4770k
