**GET MULTI-DISPLAY ABILITY WITHOUT HURTING THE WALLET!**
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
We've being waiting sometime for this card considering the sucess of the more expensive 210 version, this 610 is very impressive with 4 monitor support and the necessary cables included:-
KFA2 GeForce™ GT 610 1024MB GDDR3 MDT Multi Monitor Graphics Card @ £71.99 inc VAT
The only GeForce GT610 on the market today to support up to 4 monitors.
Features:-
- Supports up to 4 monitors in 1080p, perfect for multi-screen computing
- Multi-Monitor in Stacking and Line-up Mode
- 2x2 Stacking
- Comes with DMS59 cables
- Each cable supports two singe link DVI
Specification:-
- CUDA Cores: 48
- Core Clock (MHz): 810Mhz
- Memory Amount: 1GB GDDR3
- Memory Interface: 64-bit GDDR3
- Memory Speed: 1000Mhz
- Memory Bandwidth(GB/sec): 8 GB/s
- Texture Fill Rate (billion/sec): 6.5
- DirectX11
- Outputs: DVI-D x4 (via 2x DMS59 to Dual DVI connector)
- Form Factor: Dual Slot, Full Height
- Cooling Solution: Standard Fan
- Minimum Recommended PSU: 300W or greater (based on a PC configured with an Intel Core i7 3.2GHz CPU)
- Motherboard Requirements: PCI Express or PCI Express 2.0-compliant motherboard with one x16 graphics slot
Only £71.99 inc VAT.
ORDER NOW
