Hi there
We've being waiting sometime for this card considering the sucess of the more expensive 210 version, this 610 is very impressive with 4 monitor support and the necessary cables included:-
KFA2 GeForce™ GT 610 1024MB GDDR3 MDT Multi Monitor Graphics Card @ £71.99 inc VAT
The only GeForce GT610 on the market today to support up to 4 monitors.
Features:-
- Supports up to 4 monitors in 1080p, perfect for multi-screen computing
- Multi-Monitor in Stacking and Line-up Mode
- 2x2 Stacking
- Comes with DMS59 cables
- Each cable supports two singe link DVI
Specification:-
- CUDA Cores: 48
- Core Clock (MHz): 810Mhz
- Memory Amount: 1GB GDDR3
- Memory Interface: 64-bit GDDR3
- Memory Speed: 1000Mhz
- Memory Bandwidth(GB/sec): 8 GB/s
- Texture Fill Rate (billion/sec): 6.5
- DirectX11
- Outputs: DVI-D x4 (via 2x DMS59 to Dual DVI connector)
- Form Factor: Dual Slot, Full Height
- Cooling Solution: Standard Fan
- Minimum Recommended PSU: 300W or greater (based on a PC configured with an Intel Core i7 3.2GHz CPU)
- Motherboard Requirements: PCI Express or PCI Express 2.0-compliant motherboard with one x16 graphics slot
Only £71.99 inc VAT.
ORDER NOW
Features:-
- 2x2 Stacking
Specification:-
- CUDA Cores: 48
- DirectX11
ORDER NOW
