get name from an IP WITHOUT using DNS
Permabanned
30 Jun 2009
NI
How is it possible to get a name returned from a PC on a network without requesting it of DNS ?
I use the ws_ping_pro prog and it can sweep an IP range and return the address and name of the PC it pings without using DNS , how does it do this ?
Anyone know ?
What kind of environment is it in?
Are we talking a corporate LAN? Is it just resolving NetBIOS/NetBEUI names, or perhaps using WINS?
A little more info
This is in our companies network
For some weird reason unknown to those that handle such things
PC's entries (the PC on a static IP ) are "disappearing" from the static DNS tables
If I use ws_ping_pro I can sweep a range eg 192.168.5.XX and return the IP + name
I am looking to write a small util to sweep the range then check if it can resolve the
name to IP , if it cant then output the PC's data so I can pass it on the monkeys that
look after our network to get them to amend their table.
Its not even my problem / responsibility , but its peeing me off that when I try and vnc
onto a machine it returns address not known some of the time :-(
Is there a command to query a PC via ip and then return its name?
If so what command would do that ? ( I cant rely on DNS cos it seems to "miss" stuff )
nbtstat -A xxx.xxx.xxx.xxx
(where xxx.xxx.xxx.xxx is the IP address you want to look at)
YEP , that works great
Just gota work out how to scan the output of that command and then
gather the name info line and then output to file so I can pass it on
to the network monkeys ....... good help these days is hard to find
