not bad at all...just make sure you have no static build up by touching a radiator pipe and take your time.....making sure when you plug back in it goes in the right way and you dont force something in.....piece of cake really
Depends on the case and type of Power Supply doesnt it with regards to how hard it is to remove it. I've had some right PITA ones, to the point there was no option other than removing the HSF!
Is it standard procedure to send a few months old psu back for repair rather than just exchange it? That's what I was told they had to do "For certain manufacturers". The PSU was by OCZ..
