Get stuff back after emptying Recycle Bin?
29 Jun 2005
Glasgow
Is there a program or something that I can download or even a feature of windows to get stuff back out the recycle bin after its been emptied? I downloaded game demo (took a while) and cant be bothered to DL it again, any help would be muchos appreciated!
I believe you can do it if you have 2 hdd's but there is a high risk of file corruption?
If you install another program chances are it will semi-overwrite the deleted files. Even by rebooting and continuing to use Windows you will start to destroy what's there with the temporary internet files, prefetch etc. Best will be to put the hard disk in another computer and use software like Easy Recovery Pro or PC Inspector File Recovery on it. Don't get your hopes up too high though, there is a chance you will get it back but it's not that high if you've been using the computer since.
Lol, I typed in 'Get Data Back' into Google
And found a company called Runtime who seems to make data recovey software
Interestingly called 'Get Data Back'
http://www.runtime.org/
Their demo version (which you can download, although may be nerfed in someway, may be just what you need if it was just 1 installer exe) ?
^^^ Never had any joy with that one, even the one you pay for, so I didn't mention it.
