Got a hole in the wall where I need a fixing, a large hole. Its a 1940's house so predominately well built but with so many past diy jobs done on it over the years drilling holes and getting fixings can be "interesting"
I need to get a decent fixing in this exact place for a semi floating shelf, fixings are only 4" apart hence I say semi floating due to the load on the top fixing. The bottom raw plug is good and holding well.
I think I've got to fill this level and start again (the hole does get larger in diameter behind the bit you can see so filling should grip) but what to fill with, i think it needs to be something better than standard filler?
Hold by Peige101, on Flickr
