Getting a wee bit toasty?
Caporegime
18 Oct 2002
Ireland
In my quest to squeeze 4.8 these are temps under prime blend. Obviously games wont take it that high, im assuming a 12 hour run (assuming it doesn't bsod) at those temps wont do much in the way of pumping the cpu . :eek:
Those temps are absolutely fine..
Really? Always read that anything over 72c with a 2600k or 2500k was asking for trouble. :confused:
ed: just bsod with a 101 error, tinkering time.
Still unsure what to kep LLC at, on a few of the settings it crashes immediately, the top 2 settings seems to keep it more stable for longer but so far a couple of hours tops.
80's is fine for prime, it will never get that high under real world usage.
True, just trying to figure out the settings still, have had it at 4.6 for over a year, 4.8 seems to be trickier making use of more options, the 4.6 was literally a vcore adjustment and that was it.
Bah, looks like 4.8 is unreachable, even at just over 1.4 volts it will bsod in prime after a while, and at those volts temps are hitting the late 80's :( From what I've read the 101 bsod is core voltage, so looks like a no go =/
Yep, 101 is vcore. Been getting a few of theese tonight whilst clocking my ib 3770k. Upping voltage helps a bit but still getting a few whea errors in windows at 4.5ghz. Doesnt help that the temps are getting a bit high, (79c max when stressed).
The increase in voltage and temps to reach 4.8 isn't worth it. I normally keep my 2500K under 80 deg when benching and under 70 when gaming.
