Getting AvP to work in DX11 mode
6 May 2009
When I run the AvP.exe it works perfectly. However when I run AvP_DX11.exe it crashed immediately to desktop after the cutscenes.
I found this forum where someone gets it working but dont really understand what he means...
http://forums.gametrailers.com/thread/dx11-avp-crashes-all-the-time/1023747
"EDIT: that didn't work but i found out how to get it working now. all i had to do is make a shortcut for the ''AVP'' it plays the game in dx10 but i found out if i chang the name directory from AVP to AVP_DX11 it will render dx11 and i don't get no more crashes and so forth.working fine now"
Is anyone else having or had this issue?
I have the following
5770 using 10.3a drivers
[email protected]
P45 motherboard
Xonar essence
Windows 7 pro 64bit
All other games work fine
No problems for me, but what i dont understand is, in steam i click run in dx11 mode and it works fine. I dont even have a dx11 card:confused::confused:
Thats because although the game says dx11 it will use dx10/10.1 strings if you dont have the hardware for dx11 mode. Aka its backwards compatible :P
To the OP, do you have the febuary redist of dx11 from microsoft installed?
On the video options do you have a dx11 menu part? Inside here should be tessellation.
I got it working, it just needed patching
Cant believe how better it plays on a 5770 compared to an 8800GT. DX11, 8xAF, highest everything plays at 60fps+ most of the time
