Getting best out of card
Could you please give a little more info
What system have you got?
What games you are playing?
what resolution do you play your games at?
Have you got any money to spend on an upgrade?
you might get a little more help if you give us more info
aumz said:
I have a GeForce FX5200 128mb
How do I get the best out of it for games.
lol, but seriously.. maybe try a little overclocking? might be able to get a bit more out of it :)
I had a Geforce 4 440MX 64mb, and i upgraded to a FX5200 and it was WORSE on every game, ended up getting a 5600 which was still crap, then finally splashed out and got a 5900 :D
*Agrees with all of above* :D
Download rivatuner or coolbits so that you can up the clock speeds a little, infact up them a lot and lower its life expectancy!
Aside from clocking which wont really do much on the 5200, just make sure you have latest drivers, etc. And keep the resolutions low!
the games i play is football manager 2005 and now going tgo finally start on ms flight sim 2004
windows xp
1gb ram
3ghz p4
I'd seriously look at upgrading graphics card if you are moving onto flight sim 2004. The 5200 will really struggle!
Should be able to find a cheap 9700/5900 for around £40 and they would provide a massive jump from the 5200 and perform relatively well.
DannyW said:
You could always get a 9600XT off ebay for around £50
You can now even get a new one in the shops for the same price as they are shifting all the old stock. Bought one a few weeks ago for my brothers system. Sapphire 9600XT £49. LOL.
