Getting my sound to work in Fedora
7 Sep 2008
hi guys,
I've got an asus motherboard and I think I could alsa sound card driver installed in my fedora core 9.
I can see the volume button and it is all turned up but when I play some music on media player (can't remember name in Linux) nothing happens except it says - need mp3 decoder
I notice in the drop down menu it is currently set to Alsa HD or something like that.
just how do I even start to look into getting my sound to work in linux?
It is so frustrating
any help appreciated.
can you play a wav sound or an ogg? You may not be able to play mp3 until you install an mp3 decoder.... fedora people can tell you the command i'm sure.
I your mobo definately supported? You need to find out the sound chip and then search for compatibilty with linux. Then check the module is loaded etc. with lsmod
hi thanks for reply
I'm on that PC right now
don't have a wave file to hand but even utube vids don't display any sound even though I can see them playing
just typed in dmesg it gives this:
0/input/input3
logitech 0003:046D:C512.0001: input,hidraw0: USB HID v1.10 Keyboard [Logitech USB Receiver] on usb-0000:00:1a.0-2/input0
input: Logitech USB Receiver as /devices/pci0000:00/0000:00:1a.0/usb3/3-2/3-2:1.1/input/input4
logitech 0003:046D:C512.0002: input,hidraw1: USB HID v1.10 Mouse [Logitech USB Receiver] on usb-0000:00:1a.0-2/input1
ata2: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata2.00: ATA-7: SAMSUNG HD103SI, 1AG01118, max UDMA7
ata2.00: 1953525168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata2.00: configured for UDMA/133
usb 5-1: new low speed USB device using uhci_hcd and address 2
scsi 1:0:0:0: Direct-Access ATA SAMSUNG HD103SI 1AG0 PQ: 0 ANSI: 5
sd 1:0:0:0: Attached scsi generic sg1 type 0
sd 1:0:0:0: [sdb] 1953525168 512-byte hardware sectors: (1.00 TB/931 GiB)
sd 1:0:0:0: [sdb] Write Protect is off
sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdb: sdb1 sdb2
sd 1:0:0:0: [sdb] Attached SCSI disk
usb 5-1: New USB device found, idVendor=0b05, idProduct=172e
usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=0
usb 5-1: Product: ASUS DH Remote
usb 5-1: Manufacturer: T-wins
usb 5-1: configuration #1 chosen from 1 choice
generic-usb 0003:0B05:172E.0003: hiddev96,hidraw2: USB HID v1.10 Device [T-wins ASUS DH Remote] on usb-0000:00:1a.2-1/input0
usb 1-1.1: new high speed USB device using ehci_hcd and address 6
usb 1-1.1: New USB device found, idVendor=0846, idProduct=4260
usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
usb 1-1.1: Product: NETGEAR WG111v3
usb 1-1.1: Manufacturer: Manufacturer_NETGEAR
usb 1-1.1: SerialNumber: 001E2AB2BA25
usb 1-1.1: configuration #1 chosen from 1 choice
usb 1-1.4: new high speed USB device using ehci_hcd and address 7
usb 1-1.4: New USB device found, idVendor=05e3, idProduct=0608
usb 1-1.4: New USB device strings: Mfr=0, Product=1, SerialNumber=0
usb 1-1.4: Product: USB2.0 Hub
usb 1-1.4: configuration #1 chosen from 1 choice
hub 1-1.4:1.0: USB hub found
hub 1-1.4:1.0: 4 ports detected
usb 1-1.4.1: new full speed USB device using ehci_hcd and address 8
usb 1-1.4.1: New USB device found, idVendor=0a12, idProduct=0001
usb 1-1.4.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
usb 1-1.4.1: configuration #1 chosen from 1 choice
ata3: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata3.00: ATA-7: ST3500630AS, 3.AAC, max UDMA/133
ata3.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata3.00: configured for UDMA/133
scsi 2:0:0:0: Direct-Access ATA ST3500630AS 3.AA PQ: 0 ANSI: 5
sd 2:0:0:0: Attached scsi generic sg2 type 0
sd 2:0:0:0: [sdc] 976773168 512-byte hardware sectors: (500 GB/465 GiB)
sd 2:0:0:0: [sdc] Write Protect is off
sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdc: sdc1
sd 2:0:0:0: [sdc] Attached SCSI disk
ata4: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
ata4.00: ATA-7: ST3250310AS, 3.AAC, max UDMA/133
ata4.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata4.00: configured for UDMA/133
scsi 3:0:0:0: Direct-Access ATA ST3250310AS 3.AA PQ: 0 ANSI: 5
sd 3:0:0:0: [sdd] 488397168 512-byte hardware sectors: (250 GB/232 GiB)
sd 3:0:0:0: Attached scsi generic sg3 type 0
sd 3:0:0:0: [sdd] Write Protect is off
sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdd: sdd1 sdd2
sd 3:0:0:0: [sdd] Attached SCSI disk
ata5: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata5.00: ATA-8: SAMSUNG HD501LJ, CR100-11, max UDMA7
ata5.00: 976773168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata5.00: configured for UDMA/133
scsi 4:0:0:0: Direct-Access ATA SAMSUNG HD501LJ CR10 PQ: 0 ANSI: 5
sd 4:0:0:0: [sde] 976773168 512-byte hardware sectors: (500 GB/465 GiB)
sd 4:0:0:0: Attached scsi generic sg4 type 0
sd 4:0:0:0: [sde] Write Protect is off
sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sde: sde1
sd 4:0:0:0: [sde] Attached SCSI disk
ata6: SATA link up 3.0 Gbps (SStatus 123 SControl 300)
ata6.00: ATA-7: SAMSUNG SP2504C, VT100-33, max UDMA7
ata6.00: 488397168 sectors, multi 0: LBA48 NCQ (depth 31/32)
ata6.00: configured for UDMA/133
scsi 5:0:0:0: Direct-Access ATA SAMSUNG SP2504C VT10 PQ: 0 ANSI: 5
sd 5:0:0:0: [sdf] 488397168 512-byte hardware sectors: (250 GB/232 GiB)
sd 5:0:0:0: Attached scsi generic sg5 type 0
sd 5:0:0:0: [sdf] Write Protect is off
sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
sdf: sdf1 sdf2 sdf3
sd 5:0:0:0: [sdf] Attached SCSI disk
Freeing unused kernel memory: 404k freed
Write protecting the kernel text: 3276k
Write protecting the kernel read-only data: 1596k
[drm] Initialized drm 1.1.0 20060810
pci 0000:01:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pci 0000:01:00.0: setting latency timer to 64
nouveau 0000:01:00.0: Detected an NV50 generation card (0x092280a2)
[drm] Initialized nouveau 0.0.12 20060213 for 0000:01:00.0 on minor 0
EXT4-fs: barriers enabled
kjournald2 starting: pid 98, dev dm-0:8, commit interval 5 seconds
EXT4-fs: delayed allocation enabled
EXT4-fs: file extents enabled
EXT4-fs: mballoc enabled
EXT4-fs: mounted filesystem dm-0 with ordered data mode
type=1404 audit(1255558152.389:2): enforcing=1 old_enforcing=0 auid=4294967295 ses=4294967295
SELinux: 8192 avtab hash slots, 130022 rules.
SELinux: 8 users, 11 roles, 2768 types, 129 bools, 1 sens, 1024 cats
SELinux: 74 classes, 130022 rules
SELinux: Completing initialization.
SELinux: Setting up existing superblocks.
SELinux: initialized (dev dm-0, type ext4), uses xattr
SELinux: initialized (dev tmpfs, type tmpfs), uses transition SIDs
SELinux: initialized (dev usbfs, type usbfs), uses genfs_contexts
SELinux: initialized (dev selinuxfs, type selinuxfs), uses genfs_contexts
SELinux: initialized (dev mqueue, type mqueue), uses transition SIDs
SELinux: initialized (dev hugetlbfs, type hugetlbfs), uses genfs_contexts
SELinux: initialized (dev devpts, type devpts), uses transition SIDs
SELinux: initialized (dev inotifyfs, type inotifyfs), uses genfs_contexts
SELinux: initialized (dev anon_inodefs, type anon_inodefs), uses genfs_contexts
SELinux: initialized (dev pipefs, type pipefs), uses task SIDs
SELinux: initialized (dev debugfs, type debugfs), uses genfs_contexts
SELinux: initialized (dev sockfs, type sockfs), uses task SIDs
SELinux: initialized (dev proc, type proc), uses genfs_contexts
SELinux: initialized (dev bdev, type bdev), uses genfs_contexts
SELinux: initialized (dev rootfs, type rootfs), uses genfs_contexts
SELinux: initialized (dev sysfs, type sysfs), uses genfs_contexts
type=1403 audit(1255558152.549:3): policy loaded auid=4294967295 ses=4294967295
udev: starting version 141
pata_marvell 0000:04:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
pata_marvell 0000:04:00.0: setting latency timer to 64
scsi6 : pata_marvell
scsi7 : pata_marvell
ata7: PATA max UDMA/100 cmd 0xec00 ctl 0xe880 bmdma 0xe400 irq 16
ata8: PATA max UDMA/133 cmd 0xe800 ctl 0xe480 bmdma 0xe408 irq 16
usblp0: USB Bidirectional printer dev 4 if 0 alt 0 proto 2 vid 0x04E8 pid 0x328E
usbcore: registered new interface driver usblp
Bluetooth: Core ver 2.15
NET: Registered protocol family 31
Bluetooth: HCI device and connection manager initialized
Bluetooth: HCI socket layer initialized
ata7.00: ATAPI: TSSTcorpCD/DVDW SH-S182M, SB02, max UDMA/33
ata7.01: ATAPI: PIONEER DVD-RW DVR-115D, 1.06, max UDMA/66
ata7.00: configured for UDMA/33
cfg80211: Calling CRDA to update world regulatory domain
ata7.01: configured for UDMA/66
Bluetooth: Generic Bluetooth USB driver ver 0.5
usbcore: registered new interface driver btusb
scsi 6:0:0:0: CD-ROM TSSTcorp CD/DVDW SH-S182M SB02 PQ: 0 ANSI: 5
input: PC Speaker as /devices/platform/pcspkr/input/input5
sr0: scsi3-mmc drive: 48x/48x writer dvd-ram cd/rw xa/form2 cdda tray
Uniform CD-ROM driver Revision: 3.20
sr 6:0:0:0: Attached scsi CD-ROM sr0
sr 6:0:0:0: Attached scsi generic sg6 type 5
scsi 6:0:1:0: CD-ROM PIONEER DVD-RW DVR-115D 1.06 PQ: 0 ANSI: 5
iTCO_vendor_support: vendor-support=0
sr1: scsi3-mmc drive: 40x/40x writer cd/rw xa/form2 cdda tray
sr 6:0:1:0: Attached scsi CD-ROM sr1
sr 6:0:1:0: Attached scsi generic sg7 type 5
Floppy drive(s): fd0 is 1.44M
EDAC MC: Ver: 2.1.0 Sep 25 2009
FDC 0 is a post-1991 82077
sky2 driver version 1.22
sky2 0000:03:00.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
sky2 0000:03:00.0: setting latency timer to 64
sky2 0000:03:00.0: Yukon-2 EC Ultra chip revision 3
sky2 0000:03:00.0: irq 30 for MSI/MSI-X
sky2 eth0: addr 00:1d:60:c8:d1:c9
i801_smbus 0000:00:1f.3: PCI INT C -> GSI 18 (level, low) -> IRQ 18
e1000e: Intel(R) PRO/1000 Network Driver - 0.3.3.4-k4
e1000e: Copyright (c) 1999-2008 Intel Corporation.
e1000e 0000:02:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
e1000e 0000:02:00.0: setting latency timer to 64
e1000e 0000:02:00.0: irq 31 for MSI/MSI-X
EDAC MC0: Giving out device to 'x38_edac' 'x38': DEV 0000:00:00.0
iTCO_wdt: Intel TCO WatchDog Timer Driver v1.05
iTCO_wdt: Found a ICH9R TCO device (Version=2, TCOBASE=0x0860)
iTCO_wdt: initialized. heartbeat=30 sec (nowayout=0)
firewire_ohci 0000:06:03.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
Linux video capture interface: v2.00
0000:02:00.0: eth1: (PCI Express:2.5GB/s:Width x4) 00:15:17:71:2c:ba
0000:02:00.0: eth1: Intel(R) PRO/1000 Network Connection
0000:02:00.0: eth1: MAC: 0, PHY: 4, PBA No: d50868-003
e1000e 0000:02:00.1: PCI INT B -> GSI 17 (level, low) -> IRQ 17
e1000e 0000:02:00.1: setting latency timer to 64
e1000e 0000:02:00.1: irq 32 for MSI/MSI-X
firewire_ohci: Added fw-ohci device 0000:06:03.0, OHCI version 1.0
0000:02:00.1: eth2: (PCI Express:2.5GB/s:Width x4) 00:15:17:71:2c:bb
0000:02:00.1: eth2: Intel(R) PRO/1000 Network Connection
0000:02:00.1: eth2: MAC: 0, PHY: 4, PBA No: d50868-003
cx88/2: cx2388x MPEG-TS Driver Manager version 0.0.7 loaded
cx88[0]: subsystem: 0070:9402, board: Hauppauge WinTV-HVR1100 DVB-T/Hybrid [card=40,autodetected], frontend(s): 1
cx88[0]: TV tuner type 63, Radio tuner type -1
saa7130/34: v4l2 driver version 0.2.15 loaded
cx2388x alsa driver version 0.0.7 loaded
cx88/0: cx2388x v4l2 driver version 0.0.7 loaded
firewire_core: created device fw0: GUID 0011d800018a1afe, S400
HDA Intel 0000:00:1b.0: PCI INT A -> GSI 22 (level, low) -> IRQ 22
HDA Intel 0000:00:1b.0: setting latency timer to 64
rtl8187: 8187B chip detected.
name_count maxed, losing inode data: dev=00:05, inode=8681
name_count maxed, losing inode data: dev=00:05, inode=8694
hda_codec: Unknown model for ALC883, trying auto-probe from BIOS...
ALSA sound/pci/hda/hda_codec.c:3797: autoconfig: line_outs=4 (0x14/0x15/0x16/0x17/0x0)
ALSA sound/pci/hda/hda_codec.c:3801: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
ALSA sound/pci/hda/hda_codec.c:3805: hp_outs=1 (0x1b/0x0/0x0/0x0/0x0)
ALSA sound/pci/hda/hda_codec.c:3806: mono: mono_out=0x0
ALSA sound/pci/hda/hda_codec.c:3809: dig-out=0x1e/0x0
ALSA sound/pci/hda/hda_codec.c:3817: inputs: mic=0x18, fmic=0x19, line=0x1a, fline=0x0, cd=0x0, aux=0x0
input: HDA Digital PCBeep as /devices/pci0000:00/0000:00:1b.0/input/input6
tuner 1-0043: chip found @ 0x86 (cx88[0])
tda9887 1-0043: creating new instance
tda9887 1-0043: tda988[5/6/7] found
tuner 1-0061: chip found @ 0xc2 (cx88[0])
tveeprom 1-0050: Hauppauge model 94009, rev C3A0, serial# 752373
tveeprom 1-0050: MAC address is 00-0D-FE-0B-7A-F5
tveeprom 1-0050: tuner model is Philips FMD1216ME (idx 100, type 63)
tveeprom 1-0050: TV standards PAL(B/G) PAL(I) SECAM(L/L') PAL(D/D1/K) ATSC/DVB Digital (eeprom 0xf4)
tveeprom 1-0050: audio processor is CX882 (idx 33)
tveeprom 1-0050: decoder processor is CX882 (idx 25)
tveeprom 1-0050: has radio, has IR receiver, has no IR transmitter
cx88[0]: hauppauge eeprom: model=94009
name_count maxed, losing inode data: dev=00:05, inode=9028
phy0: Selected rate control algorithm 'minstrel'
name_count maxed, losing inode data: dev=00:05, inode=9030
phy0: hwaddr 00:1e:2a:b2:ba:25, RTL8187BvE V0 + rtl8225z2
usbcore: registered new interface driver rtl8187
cfg80211: World regulatory domain updated:
(start_freq - end_freq @ bandwidth), (max_antenna_gain, max_eirp)
(2402000 KHz - 2472000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(2457000 KHz - 2482000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(2474000 KHz - 2494000 KHz @ 20000 KHz), (300 mBi, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
(5735000 KHz - 5835000 KHz @ 40000 KHz), (300 mBi, 2000 mBm)
tuner-simple 1-0061: creating new instance
tuner-simple 1-0061: type set to 63 (Philips FMD1216ME MK3 Hybrid Tuner)
input: cx88 IR (Hauppauge WinTV-HVR110 as /devices/pci0000:00/0000:00:1e.0/0000:06:00.2/input/input7
cx88[0]/2: cx2388x 8802 Driver Manager
cx88-mpeg driver manager 0000:06:00.2: PCI INT A -> GSI 16 (level, low) -> IRQ 16
cx88[0]/2: found at 0000:06:00.2, rev: 5, irq: 16, latency: 64, mmio: 0xfc000000
IRQ 16/cx88[0]: IRQF_DISABLED is not guaranteed on shared IRQs
saa7134 0000:06:01.0: PCI INT A -> GSI 17 (level, low) -> IRQ 17
saa7133[0]: found at 0000:06:01.0, rev: 209, irq: 17, latency: 64, mmio: 0xfebff800
saa7133[0]: subsystem: 185b:c900, board: Compro VideoMate T750 [card=139,autodetected]
saa7133[0]: board init: gpio is 843f00
saa7133[0]: Oops: IR config error [card=139]
IRQ 17/saa7133[0]: IRQF_DISABLED is not guaranteed on shared IRQs
cfg80211: Calling CRDA for country: GB
cfg80211: Regulatory domain changed to country: GB
(2402000 KHz - 2482000 KHz @ 40000 KHz), (N/A, 2000 mBm)
(5170000 KHz - 5250000 KHz @ 40000 KHz), (N/A, 2000 mBm)
(5250000 KHz - 5330000 KHz @ 40000 KHz), (N/A, 2000 mBm)
(5490000 KHz - 5710000 KHz @ 40000 KHz), (N/A, 2700 mBm)
saa7133[0]: i2c eeprom 00: 5b 18 00 c9 54 20 1c 00 43 43 a9 1c 55 d2 b2 92
saa7133[0]: i2c eeprom 10: 00 ff 86 0f ff 20 ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 20: 01 40 01 02 02 01 03 01 08 ff 00 87 ff ff ff ff
saa7133[0]: i2c eeprom 30: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 40: ff d6 00 c0 86 1c 02 01 02 ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 50: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff cb
saa7133[0]: i2c eeprom 60: 35 ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 70: 00 00 00 01 40 fe ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 80: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom 90: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom a0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom b0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom c0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom d0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom e0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
saa7133[0]: i2c eeprom f0: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff
tuner 2-0068: chip found @ 0xd0 (saa7133[0])
xc2028 2-0068: creating new instance
xc2028 2-0068: type set to XCeive xc2028/xc3028 tuner
tuner 2-0068: ====================== WARNING! ======================
tuner 2-0068: Support for tuners in i2c address range 0x64 thru 0x6f
tuner 2-0068: will soon be dropped. This message indicates that your
tuner 2-0068: hardware has a Xceive XC3028 tuner at i2c address 0x68.
tuner 2-0068: To ensure continued support for your device, please
tuner 2-0068: send a copy of this message, along with full dmesg
tuner 2-0068: output to [email protected]
tuner 2-0068: Please use subject line: "obsolete tuner i2c address."
tuner 2-0068: driver: saa7133[0], addr: 0x68, type: 71 (Xceive XC3028)
i2c-adapter i2c-2: firmware: requesting xc3028-v27.fw
cx88/2: cx2388x dvb driver version 0.0.7 loaded
cx88/2: registering cx8802 driver, type: dvb access: shared
cx88[0]/2: subsystem: 0070:9402, board: Hauppauge WinTV-HVR1100 DVB-T/Hybrid [card=40]
cx88[0]/2: cx2388x based DVB/ATSC card
cx8802_alloc_frontends() allocating 1 frontend(s)
xc2028 2-0068: Error: firmware xc3028-v27.fw not found.
saa7133[0]: dsp access error
saa7133[0]: registered device video0 [v4l2]
saa7133[0]: registered device vbi0
saa7133[0]: registered device radio0
cx88_audio 0000:06:00.1: PCI INT A -> GSI 16 (level, low) -> IRQ 16
cx88[0]/1: CX88x/0: ALSA support for cx2388x boards
cx8800 0000:06:00.0: PCI INT A -> GSI 16 (level, low) -> IRQ 16
cx88[0]/0: found at 0000:06:00.0, rev: 5, irq: 16, latency: 64, mmio: 0xfa000000
cx88[0]/0: registered device video1 [v4l2]
cx88[0]/0: registered device vbi1
cx88[0]/0: registered device radio1
tuner-simple 1-0061: attaching existing instance
DVB: registering new adapter (cx88[0])
DVB: registering adapter 0 frontend 0 (Conexant CX22702 DVB-T)...
dvb_init() allocating 1 frontend
saa7133[0]/dvb: Huh? unknown DVB card?
saa7133[0]/dvb: frontend initialization failed
saa7134 ALSA driver for DMA sound loaded
saa7133[0]/alsa: saa7133[0] at 0xfebff800 irq 17 registered as card -1
end_request: I/O error, dev fd0, sector 0
Buffer I/O error on device fd0, logical block 0
device-mapper: multipath: version 1.0.5 loaded
EXT4 FS on dm-0, internal journal on dm-0:8
kjournald starting. Commit interval 5 seconds
EXT3 FS on sdd1, internal journal
EXT3-fs: mounted filesystem with ordered data mode.
SELinux: initialized (dev sdd1, type ext3), uses xattr
Adding 5406712k swap on /dev/mapper/vg_linuxasus-lv_swap. Priority:-1 extents:1 across:5406712k
SELinux: initialized (dev binfmt_misc, type binfmt_misc), uses genfs_contexts
p4-clockmod: Warning: EST-capable CPU detected. The acpi-cpufreq module offers voltage scaling in addition of frequency scaling. You should use that instead of p4-clockmod, if possible.
p4-clockmod: P4/Xeon(TM) CPU On-Demand Clock Modulation available
NET: Registered protocol family 10
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
SELinux: initialized (dev rpc_pipefs, type rpc_pipefs), uses genfs_contexts
Bluetooth: L2CAP ver 2.13
Bluetooth: L2CAP socket layer initialized
Bluetooth: BNEP (Ethernet Emulation) ver 1.3
Bluetooth: BNEP filters: protocol multicast
Bridge firewalling registered
Bluetooth: SCO (Voice Link) ver 0.6
Bluetooth: SCO socket layer initialized
Bluetooth: RFCOMM socket layer initialized
Bluetooth: RFCOMM TTY layer initialized
Bluetooth: RFCOMM ver 1.11
nouveau 0000:01:00.0: Allocating FIFO number 1
nouveau 0000:01:00.0: nouveau_fifo_alloc: initialised FIFO 1
nouveau 0000:01:00.0: Allocating FIFO number 2
nouveau 0000:01:00.0: nouveau_fifo_alloc: initialised FIFO 2
sky2 eth0: enabling interface
ADDRCONF(NETDEV_UP): eth0: link is not ready
ADDRCONF(NETDEV_UP): eth2: link is not ready
ADDRCONF(NETDEV_UP): eth1: link is not ready
nouveau 0000:01:00.0: PGRAPH_ERROR - nSource: PROTECTION_ERROR D
well as you can see I got a lot more problems apart from the sound but:
does that look like I got the drivers installed for sound?
thanks for that
I see it updated list of packages on add/remove
mmm but what now?
I played around with it and I think I've managed to uninstall the sound alsa hd that I already had.
Damn none of these ./ make install files work for me
it keeps stopping
I now see this on dmesg:
cx88_alsa: Unknown symbol snd_ctl_add
cx88_alsa: Unknown symbol snd_pcm_new
cx88_alsa: Unknown symbol snd_card_register
cx88_alsa: Unknown symbol snd_card_free
cx88_alsa: Unknown symbol snd_pcm_format_physical_width
cx88_alsa: Unknown symbol snd_ctl_new1
cx88_alsa: Unknown symbol snd_ctl_boolean_mono_info
cx88_alsa: Unknown symbol snd_pcm_lib_ioctl
cx88_alsa: Unknown symbol snd_pcm_hw_constraint_pow2
cx88_alsa: Unknown symbol snd_pcm_set_ops
cx88_alsa: Unknown symbol snd_card_create
cx88_alsa: Unknown symbol snd_pcm_period_elapsed
think TV card and Alsa:
saa7134_alsa: Unknown symbol snd_ctl_add
saa7134_alsa: Unknown symbol snd_pcm_new
saa7134_alsa: Unknown symbol snd_card_register
saa7134_alsa: Unknown symbol snd_card_free
saa7134_alsa: Unknown symbol snd_pcm_stop
saa7134_alsa: Unknown symbol snd_pcm_format_physical_width
saa7134_alsa: Unknown symbol snd_ctl_new1
I've got an asus card with a realtek chipset 8334 I think
any ideas? It is becoming frustrating Linux my firefox doesn't work so I've installed seamonkey arghhh
[root@linuxasus Core5]# cd /home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f
[root@linuxasus realtek-linux-audiopack-FC5-4.05f]# ls
alsa-driver-1.0.12-FC5-4.05f.tar.bz2 install version
alsa-lib-1.0.9.tar.bz2 Readme.txt
alsa-utils-1.0.9a.tar.bz2 test.wav.bz2
[root@linuxasus realtek-linux-audiopack-FC5-4.05f]# ./install
.....Decompress Driver source v1.0.12-FC5-4.05f
.....Decompress ALSA Library source v1.0.9
.....Decompress ALSA Utility v1.09a
Remove old sound driver
Compile Driver........
checking for gcc... no
checking for cc... no
checking for cl... no
configure: error: no acceptable C compiler found in $PATH
See `config.log' for more details.
find: `/root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e': No such file or directory
find: `/root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/alsa-kernel/': No such file or directory
make dep
make[1]: Entering directory `/home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f/alsa-driver-1.0.12-FC5-4.05f'
make[2]: Entering directory `/home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f/alsa-driver-1.0.12-FC5-4.05f/acore'
Makefile:5: /root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/toplevel.config: No such file or directory
Makefile:6: /root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/Makefile.conf: No such file or directory
Makefile:16: /root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/alsa-kernel/core/Makefile: No such file or directory
Makefile:28: /root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/Rules.make: No such file or directory
make[2]: *** No rule to make target `/root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/Rules.make'. Stop.
make[2]: Leaving directory `/home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f/alsa-driver-1.0.12-FC5-4.05f/acore'
make[1]: *** [dep] Error 1
make[1]: Leaving directory `/home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f/alsa-driver-1.0.12-FC5-4.05f'
make: *** [include/sndversions.h] Error 2
find /lib/modules/2.6.15-1.2054_FC5smp/kernel/sound -name 'snd*.*o' | xargs rm -f
find: `/lib/modules/2.6.15-1.2054_FC5smp/kernel/sound': No such file or directory
make[1]: Entering directory `/home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f/alsa-driver-1.0.12-FC5-4.05f/acore'
make[1]: *** No rule to make target `/root/realtek-linux-audiopack-FC5-4.05e/alsa-driver-1.0.12-FC5-4.05e/Rules.make'. Stop.
make[1]: Leaving directory `/home/parm/LinuxDrivers/Audio/Core5/realtek-linux-audiopack-FC5-4.05f/alsa-driver-1.0.12-FC5-4.05f/acore'
make: *** [install-modules] Error 1
Creating mixer?...done.
Creating sequencer...done.
Creating midi0?...done.
Creating dsp?...done.
Creating audio?...done.
Creating sndstat...done.
Creating music...done.
Creating dmmidi?...done.
Creating dmfm?...done.
Creating amixer?...done.
Creating adsp?...done.
Creating amidi?...done.
Creating admmidi?...done.
Creating snd/control?...done.
Creating snd/seq...done.
Creating snd/timer...done.
Creating snd/hw??...done.
Creating snd/midi??...done.
Creating snd/pcm??p...done.
Creating snd/pcm??c...done.
Creating aload?...done.
Creating aloadSEQ...done.
./install: line 42: /etc/init.d/alsasound: No such file or directory
Remove old alsa library
Compile ALSA Library.....
checking build system type... i686-pc-linuxoldld
checking host system type... i686-pc-linuxoldld
checking target system type... i686-pc-linuxoldld
checking for a BSD-compatible install... /usr/bin/install -c
checking whether build environment is sane... yes
checking for gawk... gawk
checking whether make sets $(MAKE)... yes
make: *** No targets specified and no makefile found. Stop.
make: *** No rule to make target `install'. Stop.
Compile ALSA Utility......
checking whether NLS is requested... yes
checking for msgfmt... no
checking for gmsgfmt... :
checking for xgettext... no
checking for msgmerge... no
checking for style of include used by make... GNU
Remove Folder.....
./install: line 105: alsaconf: command not found
[root@linuxasus realtek-linux-audiopack-FC5-4.05f]# ./configure
-bash: ./configure: No such file or directory
You have mail in /var/spool/mail/root
[root@linuxasus realtek-linux-audiopack-FC5-4.05f]# cd alsa-
alsa-driver-1.0.12-FC5-4.05f.tar.bz2 alsa-utils-1.0.9a.tar.bz2
[root@linuxasus realtek-linux-audiopack-FC5-4.05f]# cd alsa-driver-1.0.12-FC5-4.05f.tar.bz2
-bash: cd: alsa-driver-1.0.12-FC5-4.05f.tar.bz2: Not a directory
nah I haven't got another sound card
I am sure this should work
okay
yum install gcc gcc-c++ autoconf automake
and I got that c compiler installed
then I run ./install
and bang lots of writing but at the end it says:
checking for initscr in -lncurses... no
checking for initscr in -lcurses... no
configure: error: this packages requires a curses library
Remove Folder.....
ahh back to windows me thinks!!!
parm@linuxasus ~]$ lspci
00:00.0 Host bridge: Intel Corporation 82X38/X48 Express DRAM Controller (rev 01)
00:01.0 PCI bridge: Intel Corporation 82X38/X48 Express Host-Primary PCI Express Bridge (rev 01)
00:06.0 PCI bridge: Intel Corporation 82X38/X48 Express Host-Secondary PCI Express Bridge (rev 01)
00:1a.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #4 (rev 02)
00:1a.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #5 (rev 02)
00:1a.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #6 (rev 02)
00:1a.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #2 (rev 02)
00:1b.0 Audio device: Intel Corporation 82801I (ICH9 Family) HD Audio Controller (rev 02)
00:1c.0 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 1 (rev 02)
00:1c.4 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 5 (rev 02)
00:1c.5 PCI bridge: Intel Corporation 82801I (ICH9 Family) PCI Express Port 6 (rev 02)
00:1d.0 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #1 (rev 02)
00:1d.1 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #2 (rev 02)
00:1d.2 USB Controller: Intel Corporation 82801I (ICH9 Family) USB UHCI Controller #3 (rev 02)
00:1d.7 USB Controller: Intel Corporation 82801I (ICH9 Family) USB2 EHCI Controller #1 (rev 02)
00:1e.0 PCI bridge: Intel Corporation 82801 PCI Bridge (rev 92)
00:1f.0 ISA bridge: Intel Corporation 82801IR (ICH9R) LPC Interface Controller (rev 02)
00:1f.2 RAID bus controller: Intel Corporation 82801 SATA RAID Controller (rev 02)
00:1f.3 SMBus: Intel Corporation 82801I (ICH9 Family) SMBus Controller (rev 02)
01:00.0 VGA compatible controller: nVidia Corporation GeForce 9800 GT (rev a2)
02:00.0 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (rev 06)
02:00.1 Ethernet controller: Intel Corporation 82571EB Gigabit Ethernet Controller (rev 06)
03:00.0 Ethernet controller: Marvell Technology Group Ltd. 88E8056 PCI-E Gigabit Ethernet Controller (rev 12)
04:00.0 IDE interface: Marvell Technology Group Ltd. 88SE6121 SATA II Controller (rev b2)
06:00.0 Multimedia video controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder (rev 05)
06:00.1 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [Audio Port] (rev 05)
06:00.2 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [MPEG Port] (rev 05)
06:00.4 Multimedia controller: Conexant Systems, Inc. CX23880/1/2/3 PCI Video and Audio Decoder [IR Port] (rev 05)
06:01.0 Multimedia controller: Philips Semiconductors SAA7131/SAA7133/SAA7135 Video Broadcast Decoder (rev d1)
06:03.0 FireWire (IEEE 1394): Agere Systems FW322/323 (rev 70)
[parm@linuxasus ~]$
Google fedora easylife.
Easylife is a little application install utility that gives you a simple interface to install media players, codecs, flash etc.
First thing I install after fresh fedora is easylife ;-)
E-I
