getting scratches out of side window?
25 Jan 2008
Any tip or tricks to getting scratches out of a side window.
My Haf 922 (from OCUK) came with scratches on it. Couldn't be bothered to return it at first but now its kind of annoying me. its got a few scuff lines and what look like 2 impact scratches.
Anyone got any good tips to getting it off?
I presume its acrylic?
I doubt it unless you Polish it with real Acrylic polish (which is supposed to hide scratchs) unless you do a bit of modding and buy a new acrylic panel? :(
That happened when I bought my Gigabyte 3d Aurora case, so what I did was cut out 2 circles and put 2 x 120mm led fans into it ;)
Problem solved!
Edit, nice choice of case, I bought the vented side panel so that I could add a side fan or 2 if needed.
Problem solved!
more cooling XD
Have you tried toothpaste and a soft cloth. I've just installed a window into my computer and the pespex had a scratch right in the middle. Just spent a minute rubbing it with some Aquafresh, and you can't see it anymore. :p
^^ haha must be the three different stripes!
We want blue stripes, we want white
We want the red stripes, but thats alright
As you can see Aquafresh is all three
Aquafresh is for the family
ive heard you can use visor cleaner for motorcycle helmets as they are similar and it buffs out scratches by filling them with something works and also you can buy the stuff to stop more scratches appearing easyily aswell
Wow it actually worked a treat! scratches gone completely. thanks Cursed!
I used "Colgate whitening" incase anyone was wondering the brand, top paste!:D
And my case smells minty fresh now as well!
