- 26 Aug 2010
- West Yorkshire
Hey guys, I've just found a solution to a problem i was having with not getting the full Internet download speeds of 120mb that i should have been getting, but this brought up a strange problem with my network setup.
I have a superhub and 2 pc's directly connected to it. one gets the full 10/100/1000 speeds fine (now i changed the cabling), the other only has a 10/100 NIC so i can't test with that one. another cable from it goes upstairs into a "RJ45 Face Plate Wall Sockets Cat6 Single 1 Port with Keys" box in the wall in my room, then out to a linksys gigabit router which i use as a switch/wifi hub then into my PC. the cables from the switch to the PC and the wall to the switch work 100% but i'm only getting 10/100 speeds to the upstairs PC
the NIC is 10/100/1000 and reads as such when plugged into the linksys, however only reads as 10/100 when plugged straight into the router (through the wall face plate)
Is there a chance that the wall plate is not wired correctly or is not rated correctly? If it wasn't wired up correctly i would have thought that it would fail to work, but it works perfectly apart from the different speeds registering?
Also does the box actually effect the network speeds? All cables are cat6e from the router to the PC.
