GFX card for a u2711
23 Jun 2005
Nottinghamshire
Hi all,
wasnt sure which section to put this in as it kinda applys to both.
Wondering what spec card would be required to power the Dell u2711. It wouldnt be used for gaming, its more for photography and office work. I currently have an ati x850 xt platinum edition so not the newest of cards but good in its day.
Look forward to the advice.
Thanks
GTX460 1024MB? the Gigabyte model is probably your best choice.(just incase you might want to play the odd game or so too, this card handles all fine.)
For non-gaming purposes, I don't see anything wrong with the x850 that you have now.
Alternatively, you could purchase any number of low-end cards that would do the same job and use much less power.
