GFX Card in a Shuttle SG33G5
27 Oct 2003
I have been looking at the compatibility list on the shuttle web site and been finding it hard to find a decent graphics card to fit into this box which i can use to play games. I know i can get a 8800GTS dual slot in there but the side sticks out.
Does anyone know of a card that can perform better or borderline as a 8800gts that i can fit into this box, power it and have it actually run without it dying.
The box psu is only 250W which is more than enough.
From the compat list i think the Leadtek WinFast Geforce 9600GT 512MB is the best second is the 8600?
which gts? 512mb?
on the compat list it says it supports MSI R4850-T2D512, so a 4850? faster than a 512mb gts.
BUT 250w psu will not handle it. I dont think a 250w psu could handle a 88gts either.
well i played cysis on the shuttle with my 88gts sticking out the side and it worked fine, i was waiting for it to cut out but it didnt.
The MSI R4850-T2D512 looks like its a double slot, how can it appear on the list if you cannot get it in without modding
so basically the card you want doesnt have to be on the compat list it just has to be single slot?
GIGABYTE Geforce 8800GT GV-NX88T512H-B 512MB
thats on the list and is close to 512 gts performance.
