GFX card to order today
Sui
Sui
24 Sep 2005
Brighton
Right, I have just installed AoC which came out today, it works, but my 7800 is starting to struggle at higher settings in games. I don't have a huge budget somewhere between £100-£130 but cheaper the better really. Im looking to order it today to get it tommorow so only have like an hour to order.
Any opinions on what is the best value card at the moment?
EDIT: PCI-e, powerful PSU so thats not problem
If you definately want to order it now then has to be the 8800gt in that price range. If you hold on until middle of june then theres a possibily that ati's 4850 may come into that price also but not enough is known yet on the uk prices. It should be a good bit faster than the 8800gt. The link below shows a good deal on the bfg oc2 model
http://www.overclockers.co.uk/showproduct.php?prodid=GX-053-BG&groupid=701&catid=56&subcat=1008&name=BFG%20GeForce%208800%20GT%20OC2%20512MB%20GDDR3%20HDTV/Dual%20DVI%20(PCI-Express)%20-%20Retail
The BFG OC gets my vote aswell.
No point buying the 3870XT over it if you're looking for performance, other than if your PSU isn't up to it or something,
