GFX Card Update Advice Pls
the GTX285 is too expenive for its gain, yes if you overclock it..... it will. too bad there is alimit to how far you can push a GTX260/275
Just a quick suggestion, I have seen some horrible reviews for the coolermaster's when under heavy loads and a tendancy to go pop! The Enermax Galaxy 850W is meant to be a beast and will handle those sli's nicely.
