GFX card upgrade advise please [SOLVED]
[SOLVED]
First off thanks for taking the time to read my post.
Second here is my build:
Motherboard: Gigabyte 990FXA-UD3
CPU: AMD FX-9370 Black Edition @4.7GHz
CPU cooler: Corsair Hydro Series H100i with Corsair 120mm fans x2 pulling from 240mm radiator
RAM: Corsair Vengeance Pro Series 32GB @1333MHz
GFX Card: Nvidia GeForce GTX 650 1GB
HDD: 1TB 2.5" 7200rpm 8MB cache
Optical: Non
Case: Corsair Carbide Series Spec-01
PSU: Corsair CX Series CX750M
Front Fans: Corsair SP140 140mm Low Noise High Pressure x2 intake pushing over 240mm radiator
Top Fans: Corsair AF120 120mm Quiet Edition High Airflow x2 exhaust
Rear Fans: Corsair 120mm stock case fan x1 exhaust
OS: Windows 8.1 Enterprise x64
Third my question regarding GFX card upgrade.
I can't decide between the two cards below. I am leaning towards the Republic Of Gamers card.
Because I have been a loyal Nvidia user for some time and have no experience with ATI since long before AMD took over.
R9290-DC2OC-4GD5
ROG STRIKER-GTX760-P-4GD5
Thanks in advance,
~Krashload
[SOLVED]
Optical: Non
R9290-DC2OC-4GD5
Thanks in advance,
~Krashload
