GFX card Upgrade need a little help
30 May 2004
Hi guys
A friend has approached me regarding upgrading his HP Pavilion A6305 with a better gfx card to play dawn of war 2 as the inbuilt gfx gpu isnt enough.
Hes looking for something prob upto £140 mark but cheaper is better. He also wants an Nvidia card with at least 1gig of ram and HD connector on it(hopefully)
After looking around overclockers I found this
http://www.overclockers.co.uk/showproduct.php?prodid=GX-092-GW
The Gainward Geforce 9800GT.
Would this be ok or you guys recommend anything else?
Also from digging around a bit I think ive found his HP has 1 pciE x16 slot unfortunately at this time I cant confirm the size of the PSU in his HP machine but ill update post when i get the info.
