I'm going for 3 reference cooled GTX 780's in my rig so I've sold my MSI GTX 780 Twinfrozr gaming card and am instead waiting for an EVGA GTX 780 SuperClocked with reference cooler to arrive.
In the mean time I want to upgrade the rest of my case fans and especially the ones I have attached to the optical/harddrive cages which cools the graphics cards from the rear.
However I'm usure whether is should use a normal high airflow CFM fan as a Corsair AF 120 High Performance 1600rpm fan or if I should use a high static pressure fan like the Corsair SP 120 High Performance 2350rpm fan for cooling the 3x GTX 780 from behind.
Since the cards are pretty close to the fan and the cards have "openings" revealing the aluminium fins in the rear, I'm thinking that the best choice of fan would be high static pressure SP 120 fans since it's essentially like a "close" radiator ?
Or am I completely wrong about this ?
BTW I'm putting the fans on a fancontroller to adjust to the best noise/performance ratio.
. I've run 3-way SLi as a permanent solution in this case, since 2009 but I never have had heat issues with 3x GTX280/470/580/670 - and I still don't but I wouldn't mind it being cooler still.
